Hopeless_Diamon's avatar
Mar 17, 2016
SmartBrakeLLC
Newish guy here, usually lurking but not active.
Anyway, anyone familiar with the SmartBrakeLLC system? So far it's the only one I've found that will run off my F350 integrated Electric Brake Controller. The system seems similar to others with a control box with cable actuator that connects to the brake pedal. It connects to the truck system via the 7 pin trailer connector on the truck. Turn signals still have to be wired in, but their harness is set up so you can add them to the same connector.
So far I've only seen it mentioned in 1 RV blog, and then on their website. Not sure if it's that new or ???
Trying to get set up to drag our Wrangler behind with the camper and really like the idea of using the integrated controller.
Thx,
JR
1 Reply
  • So, found a little more info myself. Seems it's the updated Unified Tow Brake (UTB). Everything I can see is that those that use the UTB have been very happy with it
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
