WackAway's avatar
WackAway
Solar Expert Component Review Requested
I had previously been looking at the GoPower Solar Extreme "Kit" and received some very good feedback from all you folks here in the forums. It is due to that feedback that I have decided to piece my system together based on requirements and reviews.
Here is the system I have designed (below). Please let me know if there is anything that would/should cause me to worry or choose another component brand/model.
I will be wiring the panels as two parallel strings, 4 each in a series. I also will be putting in a DC combiner/breaker panel instead of fuses with appropriate gauge cabling between all components.
Solar Panels - 8 each (I have the room)
WindyNation 100W 100 Watt 12V Bendable Flexible Thin Lightweight Solar Panel
Solar Controller
Morningstar TS-MPPT-60 Tristar Mppt 60 Amp
Solar Controller Remote Display
Morningstar, TriStar Remote Digital Meter (for TS-MPPT) with 100' cable, TS-RM-2
Solar Battery Temp Sensor
Morningstar Remote Temperature Sensor RTS
Inverter
AIMS Power PICOGLF30W12V120VR 3000 Watt 12V Pure Sine Inverter Charger
Inverter Remote Switch and Monitor
AIMS Power REMOTELF Remote Switch with LCD Monitoring Screen
Inverter Battery Temp Sensor
AIMS Power PICGLFBATS Battery Temperature Sensor (for Power Inverter Chargers)
Your feedback is appreciated.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
