agwill
Oct 30, 2023Explorer
When hooked up to shore power on most RV's the power goes to a transfer switch which powers the converter that makes 12 volts to charge the battery. 110 volt ac is sent to everything that uses 110 volt ac. When not hooked up to 110 volt ac the solar panels are used to charge the battery. The battery is then connected to the inverter and produces 110 volt ac to supply 110 volt ac power to the ac outlets and fridge.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
