โJul-03-2016 10:36 AM
โJul-15-2016 06:30 AM
โJul-04-2016 10:33 PM
Jbrowland wrote:I'm waiting for this technology to mature: DSS solar panels :B (just kidding)
Question. Has anyone installed the new and lighter flexible style panels? I imagine this will be the future if they can make them as efficient as the heavier versions. It would be great to by a folding, flexible, 100w portable suitcase style panel or make it. That sure would improve portability as well as cut down on weight on the roof of an RV. For now though, they aren't as cost effective but getting closer.
One more question. Would you all feel safe leaving one of these portable solar suitcases alone and attached to the batter via gator clips while away from the RV? I'm talking about possible fire hazards not so much theft although that is certainly a consideration.
โJul-04-2016 09:25 PM
โJul-04-2016 05:36 PM
Escargot wrote:
I purchased the Renogy 100w suitcase setup in April. Used it for 6 weeks in Arizona. Ran the generator once for monthly maintenance.
I drive a B, I strap the suitcase to the back of the passenger seat when traveling.
I love the freedom from generator noise and use of propane. I also appreciate the fact that I can park in the shade, while the panels sit in the sunlight.
Ideally I'd like to have panels on my roof, too, but that can wait. I'm very happy with my suitcase!
โJul-04-2016 05:00 PM
โJul-04-2016 04:42 PM
scrubjaysnest wrote:2oldman wrote:Jbrowland wrote:At 100ah, 50% depleted is 50ah. 40w panel = 3amps, at best. 50/3= 17 hours.
Could a 40w panel re-charge a group 31 AGM (half depleted) in a day with a decent amount of sun?
I know these questions are hard to answer with so many variables. I have read so much about solar panels that my head hurts now. ๐
It will take a couple of really good days, at least.
Two 100 watt panels, some 3/4 inch pvc, 30 foot of 10 awg wire and controller will be less then a suit case portable system.
โJul-04-2016 05:20 AM
โJul-03-2016 10:32 PM
โJul-03-2016 08:02 PM
โJul-03-2016 12:34 PM
โJul-03-2016 12:12 PM
โJul-03-2016 12:11 PM
Jbrowland wrote:Yeah, even 100w is just getting by. For short durations and light loads, carrying a spare battery may be a better choice. Charge when you get home.
Looks like the 100w is likely a bare minimum huh?
โJul-03-2016 12:03 PM
So, the panels get bigger and heavier of course as the power increases. I like the idea of the 40w panel as it is easily stowed and light weight. Could a 40w panel re-charge a group 31 AGM (half depleted) in a day with a decent amount of sun?
โJul-03-2016 11:23 AM
tonymull wrote:
Those are good panels, good company. Consider that panels mounted on top mean you have to park in the sun. Works for some locations not for others. In many areas if you park in the sun so the panels work well then you have to run an air conditioner and end up with no gain. A 100w setup in full sun will give you 50AH in just less than 8hrs. Any solar will at least cut down on your generator use.
