NanciL's avatar
NanciL
Apr 15, 2014
Solved my freash water inlet problem
A few weeks ago I posted asking if any one could figure why I couldn't get water to flow into my fresh water tank using a funnel with a short hose attached to it, but had no problem using a garden hose attached to a spigot.
I got all kinds of answers, but none that solved the problem.
Today I was winterizing the trailer and was at the pump which is located under a couch, and just happened to see the fresh water fill tubing behind it. ( I never knew it was there). Looking at it, I could see a hump in it where the factory put it over the small fresh water vent tube. It made it just high enough that it was a tad higher then the filler hole. The pressure of a hose from a spigot forced the water over it, but my gravity fill didn't and it just flowed back out of the hole.
Mystery problem solved !
jack L
  • Nice - always appreciate when somebody posts what the fix was to an issue. Too often they are never heard from again once they figure out what the problem was but we are left guessing!
