โJul-05-2017 02:08 PM
โJul-13-2017 08:19 AM
phillyg wrote:
Snip...
The thread has been steered far from the original question.
โJul-13-2017 05:37 AM
โJul-13-2017 04:48 AM
Grit dog wrote:phillyg wrote:
Grit Dog said, "Typical closed minded 'retiree' mentality, IMO."
Nice to lump all us retirees in one pot there, Grit. I'd like to think that us old folks have a bit more wisdom.
Not all, just typical based on observations here AND in the real world. Notice I never condemned driving slower, just that others impart the "my way is the only way" on here like it's gospel and those of us in a hurry are somehow offending them or an impending disaster on wheels.
And you can pretty much tell whos driving a RV by how fast they're going. Running down any freeway, the loafers typically are my parents age and those keeping up with traffic are usually younger. Just how it is.
Cheers. See you in the slow lane!
โJul-13-2017 04:35 AM
Grit dog wrote:noteven wrote:
I'm retired.
When I'm riding one of my bikes I'd like the lardass rv's only doing 75 to get out of my way. ๐
That's what I'm talkin about! If they weren't meant to go that fast, the speedometer would t go that high!
โJul-12-2017 09:35 PM
I'm retired.
โJul-12-2017 09:13 PM
noteven wrote:
I'm retired.
โJul-12-2017 01:11 PM
โJul-12-2017 12:52 PM
hotpepperkid wrote:
Get rid of the ST tires and go to LT then you don't have to worry about the speed rating of China made tires. They will have the same speed rating as your TV
โJul-12-2017 11:28 AM
โJul-12-2017 09:40 AM
โJul-12-2017 09:05 AM
GoPackGo wrote:
This doesn't make sense to me. If a tire starts to leak down, why would it 'blowout' as mine did ? I don't think it would. It would continue to leak air until pressure is equal to the outside, while the tire disintegrates. A blowout will result from some kind of catastrophic failure, not a slow leak.
โJul-12-2017 06:02 AM
enblethen wrote:
I somewhat agree with Grit dog.
I agree having worked many hours and days. It was hard to do longer trips without lots of windshield time.
I disagree though with having drive to the point of being a hazard to others. Driving faster could and does at times create more issues then blown tires.
As a retiree, I try to avoid long holidy weekends. I try to find a location so worker bees have a better chance to find what they are looking for during these weekends.
โJul-11-2017 09:28 PM
โJul-11-2017 09:08 PM
myredracer wrote:
Heat kills tires. Running under-inflated creates heat and doesn't take long. Add over-speed and/or overloaded and a failure will happen even sooner. The internal heat damage is cumulative and irreversible so if tires have a prior history of being under-inflated, overloaded and/or used over their speed rating, a failure will happen even sooner still. Could be internal impact damage too that can't be seen.
Below is a photo showing melted body cords as a result of overheating that resulted in a blowout. I'm on the side of the fence that believes that the vast majority of "blowouts" is operator error and not cheapo tires. You could always dissect a tire that has failed to try and determine what happened. How many actually weigh their trailers to see how close they are to the max. rating and if one side of the trailer is heavier and maybe overloaded? How many check pressure and inspect for physical damage before each leg of a trip? How many do what they can to avoid hard impacts in potholes and stay off road shoulders where there could be shrapnel? How many run ST tires below their max. sidewall psi?
I think too many rely on TPMS warnings to save them when they would be better off taking better care of the tires instead. I also think the vast majority of ST tire owners have no idea how to take care of them and get so surprised when there's a failure and then they go on a forum and accuse the country of origin. Can't blame them in way - who ever tells them? Not the dealer and not the RV manufacturer that's for sure.
There's a lot of excellent info. on RV tires in Roger Marble's blog if anyone would take the time to read through it. Have not seen anything better and more in-depth elsewhere. Photo is from his blog.
