SpeakEasy's avatar
SpeakEasy
Suburban Oven Not Lighting
I'd like to know how common it is to have to replace a thermocouple in an RV oven.
My pilot will light, but as soon as I release the knob and try to turn the oven on, the pilot goes out. It doesn't matter how long I hold the knob in and heat the thermocouple. I believe the thermocouple needs to be replaced, but it seems like a fairly unusual thing to me.
(All other gas appliances work perfectly, including all three burners on the cooktop.)
Have any of you had to replace this?
Is there a different cause I should be considering?
Thanks,
-Speak
  • OP here.
    I ordered a new thermocouple and installed it this week. Pretty simple job. The oven works perfectly now.
    -Speak
  • I fought mine for 11 years. You need to hold the knob in for at least a minute. If you feel there is a problem, take a piece of fine steel wool and polish the thermalcouple bulb. Also you can carefully move it a bit closer to the flame.
