centerline's avatar
centerline
suggestions for a better shower head????
im looking for suggestions for a shower head that will give a wider spray of water.
the one that i have now sprays about a 2inch pattern at 24inches from the shower head, and I would prefer to have one that has about a 5inch spray pattern....
due to heartlands use of the plastic fittings in the 1/2" pex line, which only have a 5/16 pathway thru them, more water flow and pressure is not an option without replacing all the joints with metal fittings, or upgrading to a larger size line thruout the freshwater plumbing system....
those of you who have a good spray pattern from your shower head, what brand or type are you using?.... thanks
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: May 20, 2013
