sennister's avatar
sennister
Sway Control and WD Hitches
We went to the RV Show here locally this weekend and just started the buying process for a new camper and wanted to double check a couple things.
Truck Specs from GMC:
2011 Yukon Denali (short one not XL) AWD
TWR: Trailer Weight Ball: 8100lbs
GCWR: 14,000
Curb Weight: 6,000lbs so that gives us 8,000lbs for the camper, the family and all of our stuff.
Ball Weight: Class IV 10-15% trailer; 1200lbs max
The truck does have the optional factory brake controller
Like all Denali's it has the rear air shocks with load leveling.
Trailer Specs from Jayco: (I didn't take a photo of the dataplate so this is an estimate from the website so ballpark numbers not taking into account options)
2017 Jayco Jay Feather 25BH
UVW: 5265lbs
Dry Hitch: 640lbs
GVWR: 6750lbs
So from a towing capacity we should be staying away from the max capacities well enough to be good. We live and will be camping mainly in MN and WI mostly within 150 miles so only mild hills no mountains or high altitude stuff planned. We don't get crazy winds here normally.
With my current camper (22' Dutchman) we have been using a Draw-Tight WD hitch rated for 12,000lbs with the 1200 spring bars that support up to 1200lbs Tongue Weight. This is the chain style and we have never used a sway control bar with it as I don't have one. This hitch was probably too big for what we were using.
In talking with sales, I said I wasn't sure what the rating was on the hitch and inquired about this. She stated that for the trailer we are getting they normally recommend at least a 10K hitch or 12K might be a bit better. They use the Equal-i-zer and I guess from the stand point of it will give me sway control without another connection that I have to take off when parking it might be nice. They are asking $795 for it though and I have found it for less ($510 on Amazon) or they said they will move what I have now over for free. I might ask them if they will price match.
I assume that this would also mean that if I bought the one from Amazon they would install that one for free when we go to get the camper. Though it isn't like it is hard to bolt up and mainly looking at a bit of time setting it up. I have a level section of driveway. So should I just have them move what I have now and then get consider getting either the sway control later if I need it or upgrading the bars to the other design that provides sway control?
I guess I don't know how much I will need it on the camper though this one is bigger both in length and weight. I do know that if I don't get it and have it set up that means I might be mid trip and get into cross winds or some other condition where I wish I had it. This is why I am leaning toward just going with the Equal-i-zer or something similar.
Do my numbers look good and thoughts on what to do with the WD hitch/sway control?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
