Mike134 wrote:
loydt wrote:
Just bought a new Jayco White Hawk 32BH. It has a GVWR of 9995 Lbs and a dry hitch weight of 1,100 Lbs. My truck is a 2018 Ram CC 4x4 dually with the Cummins/Aisin combo and a factory class V hitch. Do I need to mess with a WD hitch for this massive truck?
I don't think folks read word questions very well here based on the responses.
You have a 1-ton dually that has a payload in the neighborhood of 5500lbs. Was factory equipped with a class on V hitch. Those can have a 18,000- 20,000 rating. You have the extra heavy duty transmission for that diesel. I'd bet if you dropped 1800 lbs of tongue weight on that beast of a truck your front wheel well height might go up 1/4". If you properly load the trailer you won't need sway control because a "PROPERLY" loaded trailer won't sway.
Just my 2 cents based on the information you provided.
Looking forward to your (5) scale tickets where you’ve shown us tire and axle loads isolated. As well, your COG calculations
All trailers sway once to the right speed on a given road under given conditions of wind. There are no constants, is the problem. It’s USUALLY in the transitions from one state to another that things go haywire.
Know when I’d like to see you blow a rod thru the block? As I’m just under the posted construction zone speed limit yanking a 53’ and we have DOUBLE camber changes at each end of a bridge diversion . But there you go passing me (again) blind to vehicle dynamics in every sense of the word when we both have combination vehicles.
Think of it this way: Trailers DONT move side-to-side. They ROTATE in an arc that increases over the travel length. Longer the trailer, greater motion at the farthest end.
That ROTATION means a trailed 1,800-lb construction-site compressor can whip a DRW right off the road. Empty bed, low tire load, shiny concrete. Seen it more than once.
“Properly-loaded trailer” is pretty much meaningless for TTs except toy haulers where bad mis -judgment can come into play.
Camber changes, tripping hazards, curbs, etc are the invisible subjects on RV boards.
