agesilaus's avatar
agesilaus
Jun 05, 2022
Tip for getting film off the back of double sided tape
It works!
Tip
He uses some special comb but I found a regular comb with fine and coarse teeth works, just use the coarse tines. I scribe a shallow cut into the film with a sharp knife tip, just thru the film. Then use the comb to separate the film at the cut line. Don't carry the cut all the way across, and then you can peel both sides of the cut.
  • 2112's avatar
    2112
    I use my fine tip tweezers that are generally dedicated for SMD soldering. This bald guy doesn't own a comb
  • I just hand it to Herself and with her fingernails she can do the job in half the time. :w
  • CA Traveler wrote:
    Good tip, thanks. Doesn't work for label tape but my last purchase has length wise split backing and very easy to remove. All tape should be made this way.
    I agree 100% and do not understand why they all do not make the tape that way
  • Good tip, thanks. Doesn't work for label tape but my last purchase has length wise split backing and very easy to remove. All tape should be made this way.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 05, 2026
