JimK-NY wrote:
If you have a TPMS, you might want to try an experiment. Wait for a hot Summer day with the sun beating down on the pavement. Watch what happens to the tire pressures when you start out at the cold pressure corresponding to the maximum load rating. After the tires cool, try the same experiment starting out at the maximum inflation pressure. You will likely see the roughly the same final operating pressure and may even see operating pressures higher for the tires that started out with lower pressure.
Or in summary, temperature and altitude affect tire pressure.
PV=nRT still works.
Not sure what you were trying to say about seeing higher pressure on tire that started out with lower pressure, other than...
Pressure changes about 1psi per 10 deg F and about 1/2 psi (slightly less) for every 1000ft of elevation change.
