Tire Pressure Monitoring Systems
SHRED
I need a tire pressure monitoring system for my Honda CRV tow vehicle.
I have a 27 foot class c Lazy Daze motorhome that has a system already.
Is there any decent 4 sensor systems under $200 that have the distance range to work?
Thanks
2021 27' Lazy Daze mid bath
7 REPLIES 7
Monkeyman_and_L
SHRED wrote:
Beverley&Ken wrote:
What type of system does your LazyDays have? If it is TST, they have a kit with the four sensors and a REPEATER to add on there system. If not TST they also have a 4 sensor kit with repeater and Monitor.
Most systems are not interchangeable with other manufacturers.
Ken
It's the built in FORD E-450 system.
Is the built-in just the idiot light version? If so, get a TST with enough sensors for all your tires and roll with that. Depending on your pressures that dashboard warning light might be set for way lower than what you should run your tires at for the rig you drive. That way you can monitor temperature too.
Monkeyman, Lady and little chimp
2018 Newmar Baystar 3414
2022 Ford Escape Hybrid TOAD
SHRED
Just bought a TST-507 on etrailer.com.
Thanks for the help.
QCMan
Nomad III
Nomad III
I wouldn't want to cheap out on a tpms. The potential damage is way too high even with a toad.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
dodge_guy
I don’t know of any good TPMS system that would be $200.
I would go with a TST507. It comes with a repeater that will be needed.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
SHRED
Ken
Beverley_Ken
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
haste_maker
I have the TST system for my Rv & toad...works great.
Retried Teamster
2007 Allergo
