TheBar
Dec 18, 2018Explorer
A friend who owns a tire store says a tire that is under-inflated runs hotter due to increased sidewall flex. This heat is what causes blow outs on tires that are within their normal life span. Old tires may blow out due to cord failure no matter what the pressure or heat. Newer tires may blow out due to previous cord damage from a big pot hole or running over a curb. Unless a viable tire is way over-inflated when cold it won't blow out when on the road because it runs cooler at higher pressure. The small increase in pressure due to higher ambient temperature are not enough to cause failure.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 21, 2026
