BobsYourUncle
Jan 17, 2021Nomad
Bobbo wrote:
A strap around the center of the tire with a ratcheting clamp will seat the bead without using air.
This does work, except you gotta put some air in it to hold the beads.
I have used a ratchet strap many times putting a tire back on a rim when just air won't seat the bead.
I have also tied a piece of rope around the tire, insert a tire iron, a flex bar or similar into the rope, making a twist, and then rotate it several times to tighten the rope around the tire. Then hit it with the air chuck.
Another trick is to take the valve core out so the air gets in there faster.
It works!
I used to do all my own tire work a lot of years ago.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 08, 2025
