RedG's avatar
RedG
Tired of pulling that fuse?
I've seen some fuse switches on the internet for some hefty prices so you don't have to pull the ignition/accessory fuse every time you hook up the toad, but decided I'd make one from stuff in the garage for free. Here's how I did it.
Get one of these Fuse Taps from Autozone or other auto store. (I had one in the garage)
In the front fuse slot, plug the fuse into one side of the tap with the other tab hanging off the side. Take a wire with a spade plug on the end and plug it into the lug of the fuse hanging off the side of the tap. (This fits nice and tight and makes a good connection}
I then cut an old fuse in half to get one lug from it and inserted it into another spade plug with a wire on it and plugged it into the other slot in the tap. Then just run the two wires to any kind of on/off switch. Plug the tap in, route the switch and you're done. Mine looks kind of crude right now and I may use a more modern looking switch before install, but this is quick and easy and will save me from having to pull the plastic side off the console of my Malibu every time I pull it behind the MH.
