Bobbo
Jun 25, 2016Explorer II
boomersooner1986 wrote:
For those using the Ready Brute Elite, what do you use (or do you) to maintain the battery charge? Or is this even an issue?
Since the Ready Brake does not use any power, the answer is whatever your car's owner's manual says. My Subaru has no battery drain so no charge line is necessary. If your car says pull a fuse, either pull the fuse or install a charge line.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
