Hi all, Can I safely tow using tires rated "XL" (I.e 115s, 119r etc) vs the "e" rated? I'm still new to towing, but would like to tow my TT safely. I'm currently using the stock Bridgestone Duell...
I switched from Firestone tires to the Nitto Terra Grappler and could not be happier with the Nitto tires. There are two types, a D and an E rated version and you can save money with a 1/2 ton truck getting the cheaper D rated ones.
I put the Nitto 285/70R17 on my 3/4 ton truck and no problems with clearance. If a tire is 1" taller than the stock ones it is only going to extend out at most an additional 1/2 inch.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 08, 2025
