gfortelney
Sep 03, 2018Explorer
NMDriver2 wrote:
One possible cause is the rubber portion of the fuel line near the transmission is collapsing.
This is a known problem with the 08 Chevy diesels (like mine). There is no fuel pump and that is part of the problem. You can install an aftermarket fuel pump, like FASS, for around $1200 and that will solve the problem. You can also change the portion of the fuel line that is rubber, instead of metal like the rest of the line is, for around $150. There is a tech bulletin out on how to do that and the correct material to use.
Generally this surfaces when towing up hill in high temperature. The engine wants more fuel and sucks the hose down until the computer believes there is either a clogged fuel filter or some other problem that results in low rail pressure. If you go to a dealer they will likely try to charge you for a full rail and injector job ($15,000).
Any competent mech can do hose exchange job and the hose can be fabricated following the specs in the bulletin.
I will try to find the bulletin and post it as an edit.
This discussion on the Chevy Duramax forum may help. Poster JC1843, the third one down after the initial question, has all the info you need.link
It did keep triggering the change fuel filter message, I went through 4 fuel filters and it did not help. Went to the dealership and bought a new diesel fuel filter housing assembly that had a new filter and water sensor and put it on and reset fuel filter life. Made it 30 miles and it said 0% fuel filter life. When I hooked up the trailer and was pulling it under a load for about 10 miles (probably enough to get hose heated up so it could collapse) it through the P0087 error code and also said 0% fuel filter life.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
