โSep-26-2020 01:56 PM
โSep-29-2020 05:45 AM
Lwiddis wrote:
Donโt buy any vehicle to use as a four down toad unless the manufacturer says you can and you comply with any requirements. For instance, 2020 Chevy Equinox...two wheel drive...four down ok...all wheel drive...no. You may need a dolly depending on the toad you buy but they are a pain...three vehicles instead of two.
โSep-28-2020 09:51 AM
โSep-28-2020 04:59 AM
rk911 wrote:dodge guy wrote:
...All Wranglers are 4 down towable, manual or auto...
all current year Wranglers might very well be flat towable but in case the OP is considering buying a used Wrangler the advice is the same...check the owner's manual under Recreational Towing before purchase.
โSep-27-2020 03:42 PM
rk911 wrote:
yeah, the A/B switch is not a precise analogy. :@
โSep-27-2020 01:59 PM
Jack Spratt wrote:rk911 wrote:
clicky
and from personal experience i'd recommend installing a separate wiring harness ans bulbs in your jeep. it sounds harder than it really is. when we started towing back in '03 the diodes (which function like an A/B switch) in the original wiring harness kept blowing leaving us with no tail lights or blinkers. we put in a second set of bulbs in our jeeps connected directly to the umbillical connector in the front of the jeep.
Sorry to hear about your problems with your previous wiring.
I donโt know about the A/B analogy
the current diodes pass current from either source and do not backfeed
to the other leg.
Anyway FWIW ours have been trouble free in two different vehicles for many miles
โSep-27-2020 01:43 PM
rk911 wrote:
clicky
โSep-27-2020 11:42 AM
โSep-27-2020 10:10 AM
โSep-27-2020 08:59 AM
โSep-27-2020 04:18 AM
โSep-27-2020 03:17 AM
โSep-26-2020 08:17 PM
RLS7201 wrote:
Your best source of towing information is Remco Towing.
Richard
โSep-26-2020 07:56 PM
โSep-26-2020 05:28 PM
