shannon62's avatar
shannon62
tow vehicle
can any body tell me if i can dolly a 2007 mustang back wards behind a class a motorhome?also how to do it?
  • In spite of the naysayers and their dire warnings, I used to see such a rig zipping happily down the freeway locally quite often. True, not much recently. Apparently, if it isn't towable on a dolly or four down, it gets left home.
    the fact remains, towing on a dolly backwards has been done in the past, and probably will be done again.
    Would I put my '66 Chevelle on a dolly backwards? No. It will sit at home. Being towed is what the Jeep is for.
    Can a vehicle be towed on a dolly backwards? Yes.
    Will it cause irreparable damage? Probably not.
    Good luck.
  • shannon62 I would consult your owners manual or talk with Ford if your set on towing backward. I think you’re going to be better off if you put it on a trailer personally.
  • My guess is that it wouldn't take long for that low front end to be removed by a Pennsylvania pothole.
    How to do it? Put it on a trailer.
  • I think you are asking to tow it like a tow truck sometimes would with the turn wheels on the ground. I would ask a tow truck driver on that one but then again also how far are you talking about towing this? If it is a long haul I would put drive wheels on the ground. I would disconnect the drive line so trans doesn't turn.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: May 28, 2026
