williamswl's avatar
williamswl
Tow vehicles
I want a small truck like an S10, Ford Ranger, Mazda or whatever you can tow all wheels down the easiest. Is there a creature that you can hook up, pop in neutral, and get going? Or what is the best small truck to pull even if you have to un-do something?
Thanks in advance for any help.
  • I am new to the RV world. To clarify...is a 2006 Ford Ranger regular cab 2WD 4 cylinder automatic an appropriate tow vehicle?
  • That describes my 5 speed manual 2001 Ranger. Except that I leave a key in the ignition, "unlock" position, to ensure that the steering wheel does not lock.
    Towing approval is given for Ranger with the Mazda-built M5OD-R1, but not for the other eleven transmissions used in the 28 year life of the Ranger brand on Ford compact trucks (five different bodies). M5OD-R1 became standard with the 1993 model year, but I would not consider towing something earlier than 1998, the year Ford finally scrapped the Twin I-Beam front end on the Ranger.
    If I were to do it again, I think I would look for a 2WD Ranger XL, instead of the Edge. The Edge has the 4WD suspension, even on 2WD, thus a higher center of gravity.
    Nissan OKs towing the 5-speed Frontier, Mazda B with M5OD-R1, Chevy is OK with towing 4wd Colorado.
    Toyota does not treat the manual transmission Tacoma as towable, whether 2WD or 4WD. Neither did GM recommend towing S-10 or S-15 on basis of manual transmission. There are probably transmission output shaft lubrication issues. This has not prevented people successfully towing these trucks, it just means you are on your own if you burn up a transmission. Old compact pickups with manual transmissions are pretty cheap, mess one up, buy another.
  • 2 wheel drive 4 cylinder
    in addition to a string of 8 lug full size trucks with the largest engine available :
    i have owned some small 2 wheel drive entry level trucks with 4 cylinders , stick shift .
    i owned a 1980 chevy luv mikado ( ISUZU ) with the 80 hp . I abused that little truck for years and then my son did the same . ZERO repairs for the 8 years I owned it .
    i replaced that with a nissan 4 cylinder with the stick shift . same thing .
    i overloaded both of these on occasion , towed a 16 foot fibreglass boat with them , ran them to the maximum rpm in every gear frequently .
    we literally tried to blow them up . it did not happen.
  • You should post this under Dinghy Towing for better results. I'm sure a moderator will be along shortly and move it. :)
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 09, 2025
