drifterpilot
Mar 29, 2019Explorer
Towing 2019 Chevy Colorado 4-Down
My owners manual states the following:
CAUTION. Failure to disconnect the negative battery cable or to have it contact the terminals can cause damage to the vehicle.
Can anyone explain this statement or is it just to CYA (Chevrolet)?
I utilize the Blue Ox Towing System with the BrakeBuddy auxiliary braking system. I need an active 12-volt connector to power it. I am aware that I can connect the 12-volt socket right to the battery.
I really don't want to disconnect the neg batt cable every time I set up to tow.
Does anyone flat tow a toad successfully without disconnecting the neg batt cable even though their manual states otherwise?
Thanks
Thanks
