Ryan01463's avatar
Ryan01463
Towing a Jay Feather 19H with a 2009 Nissan Pathfinder SE
Any worries here? Most towing will be 2 hour trips from northern Massachusetts to the White Mountain Region in New Hampshire. Not a ton of large up hill roads, mostly long inclines and 90% of the travel will be highway. Weight Distribution Hitch and Sway bars needed?
Ive seen this exact vehicle towing much larger campers on the highways and parked at camprgrounds.
Any insight is greatly appreciated.
Trailer Specs
Unloaded vehicle weight (lbs.) 3615
Hitch weight (lbs.) 440
Gross vehicle weight (lbs.) 4950
Cargo carrying capacity (lbs.) 1335
Vehicle Specs
MAXIMUM TOWING CAPACITY** 6000 lbs.
MAXIMUM PAYLOAD** 1564 lbs.
GROSS WEIGHT 6000 lbs.
CURB WEIGHT 4446 lbs.
