campingman55's avatar
campingman55
towing a malibu
ok i am going to tow a 2005 chevy malibu 4down the thing i dont get is not to go over 60 what would it do if i whent over 60 and it has the right tranny to tow 4 downand we are useing a ready brut and demco base plate and magnet lights we have a 40 dp
  • Actually I think the restriction is for 65 MPH not 60. I don't tow any faster than that anyway.
  • They have to give you a number, 60 is the number GM chose for that transmission. Towing faster generates more heat, too much heat and the tranny can explode, but that 60 is not hard and fast.
    For a mismatch in height usung a towbar, the correction is made with a drop receiver (which can also be flipped to raise the opening at the RV). My hitch is also at 17, two inch drop puts it within safe height for baseplate on the Fit, two inch rise brings it level withthe tabs on my truck.
    BlueOx and Roadmaster make the drop receivers, different load limits, different offsets. I've seen 2", 4"' and 8", some at 5000 pounds tow and 150 tongue weight, others up to 8000 tow, 500 tongue weight. They are not cheap, my 2" drop was $80 from E-trailer, dealer wanted almost twice as much.
    You want the connection at the MH end of the towbar to be slightly above or level with the connection at the towed vehicle, to prevent it lifting the towbar durung braking. BlueOx frequently gives 3" tolerance, Roadmaster 2", depending on towbar model. But that's not level plus or minus 2-3 inches, it is level to towed vehicle 2-3" lower.
  • I don't understand 2nd post.I am on my 3rd Malibu,(04) (08)and now a (12)
    I have had no problems with them related to towing.
    I have occasionaly gone over 65, going downhill etc.
    I notice that the transaxles/tranny get warm from towing so it would be logical that the faster you go the more heat you generate.Thus future problems
  • also it is 17 inchs from the ground to the center of the reciver on the coach what lenght if any do i need to make it level
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
