fr8rplt's avatar
fr8rplt
Towing MKX/Edge
Just purchased a 2013 MKX and will be useing it for toad purposes. It has the keyless entry/button/remote start option. When following the instructions in the OM several instrument panel(either side of the speedo) lights stay on after the shift lever is in neutral and the engine shut down. Specifically the the gear indicator lights and the warning light "shift to park". My question is will these lights run down the bat while towing, is there a fuse to pull, or do I need a trickle charger? The OM does not address any of these issues and thought maybe one of you towing a MKX or Edge might have the answer.
Thanks Tom
  • We are just starting to tow a 2013 Edge With car in neutral and ignition in accessory as per instruction car will not lock Am i missing something?
  • One thing we have forgotten a time or two is to turn off the headlights. If it gets dark with it in the auto position on they come and will drain the battery.
  • Our 10 Edge tows fine and the battery doesn't run down with the charge wire and Roadmaster tow bar except when wife leaves the switcch in the accessory notch and not all the way back. With the ignition in the accesory spot, notch or whatever you have electricity routed from the car's battery to the accessories and lights and the wire from coach out of the circuit.
    We talked with someone in Savannah with an 11 Edge with the push button start and they encountered the same problem. They followed the then current manual, which seems to have left out something and the battery was dead after towing.
    This subject has been encountered before here but I can't recollect a solution.
  • We have an 07 MKX ... original owners. I installed a hot line from the coach thru the Umbilical cord to the battery so that it would charge while driving the coach. Also within the hot line under the hood installed an inline diode so as to NOT have back feed to the coach. Without it (before I installed it) when turning the coach ignition off ... the engine keep running. My MKX battery (before the hot line) would get weak on long runs because the GPS would continue running along with whatever is hooked up when the ignition is in aux position.
  • Looks like in motorhome towing guide, it does not state to pull fuse. Both car instructions are the same." Run engine at beginning of day for 5 minutes (shift into drive,then reverse, and neutral) and every 6 hours thereafter.
  • Is this a MKX Lincoln or is this a Edge. It should state in the owners manual. If a Lincoln Fords web page states it is not towable 4 down. Maybe someone will join in .
    On page 228 and 229 of the third printing ,if a Lincoln, It says that you can flat tow behind a Rv. It gives the instruction on setting up, which I am sure you have read. Have not found anything on the lights.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
