Mar-09-2015 10:34 AM
Mar-21-2015 05:09 PM
Mar-10-2015 07:45 AM
Mar-09-2015 06:42 PM
Mar-09-2015 04:56 PM
Mar-09-2015 04:13 PM
dhatcher wrote:
Yeh I saw that too in the fine print about "properly equipped." Thing is, the Xterra doesn't come with different gear box options and mine is the Pro-4X model so it has the most upgraded suspension setup that Xterra's come with (little bit beefier shocks from bilstein is really all it is). If you price out an Xterra with options on a website like edmunds you'll see there is no opportunity to check off something like an upgraded trans cooler. That's why I wondered what they meant when they said "properly equipped." Maybe I will call the dealer and see what the service department says.
As far as tow weight goes, my wife and the dog and I make up about 500lbs of weight and the stuff we bring is probably another 150lbs +/- of weight. So even if we subtracted 700lbs from 5000, I should still have approximately 4300lbs available. The trailers I'm looking at seem to be under that but, I wonder if it's wise to get close to that or whether I should be looking at like, half that weight as a more realistic goal.
Mar-09-2015 03:14 PM
Mar-09-2015 03:09 PM
Mar-09-2015 02:55 PM
Mar-09-2015 02:30 PM
dhatcher wrote:
max payload is 1,053lbs
max tow is 5,000lbs
Yeh, I'm on one of the xterra forums but, it is not as well suited for towing info as here 🙂
Mar-09-2015 01:21 PM
Mar-09-2015 01:12 PM
Mar-09-2015 12:00 PM
Mar-09-2015 11:53 AM
Mar-09-2015 11:28 AM
