thestrangebrew's avatar
Apr 10, 2014
Towing with 2013 XLT w/Tow Package
Hey all! New to the forums and doing a bunch of research. I've done a search with people asking if a 2013 explorer can pull xyz TTs and most recommend for this particular TV either a popup or HTT. We're currently looking at a Jayco 16xrb HTT and I just want to check if I'm (roughly) calculating my numbers correctly.
So the Jayco GVWR is 3500lbs and dry weight of 2575 lbs. A lady on the Jayco Forums (I've posted on several different forums in my research) who has this exact trailer bought in Feb. saying her yellow sticker was 2832 lbs. I know this number could vary immensely, but just as a baseline I'll use that number.
Curb weight of TV - 4557lbs (including 150lbs for driver)
Passengers (3 - not including driver) - ~450lbs
No cargo (wife said we will put all our gear in the trailer when towing which I'm totally skeptical about)
tongue (dry hitch?) - 315 lbs (most likely higher from what I've read)
Weight of vehicle + passengers + 0 cargo + tongue = 5322 lbs
So dry weight - 2832 lbs
Trailer has 26gal fresh water capacity, but we don't use a whole lot of water and to keep things light, I fig. we would use about 10 gals over the course of a weekend. I'll go with 15lbs just to be safe.
Water @ 15 gals. = 8.33lbs/gal = 124.95 gals.
Propane & battery = 125 lbs(?)
Cargo (I have no idea what food/clothes will weigh and we generally use paper /plastic products) so I'd guess about 200-300 lbs
Weighted vehicle (dry weight + water +cargo (300lbs to be safe) = 3381 lbs
TV + Weighter Trailer = 8703 lbs.
My TV GCVWR is 9980 so 9980 - 8703 = 1277 or 87% of Max
Does this sound about right as to how I would figure out actual weights etc once we decide to get the trailer? @ 87% would I have a hard time going up some mountains? I will be using a wdh & brake controller and anything else that will enhance safety that you guys would recommend (I've never pulled anything before so this is all new to me). Thanks.
