Towing with a Ford Explorer
Convington
Hey guys,
I was pointed over here by another forum because I'm getting a bit of conflicting info.
I have a 2015 Ford Explorer Limited with a V6 3.5L engine. I do NOT have the Ford Towing Package on it. I do have a CURT Class III hitch purchased from eTrailer about 5-6 years ago. I have only used that hitch so far to pull a Canoe.
Looking at Travel Trailers and see that most of them are running anywhere from 3500# to 5000# for what we want.
My Ford dealer, when talking to "the hitch guy", says that even with the 3rd party hitch my vehicle can easily pull 5000#. The other forum has information that says you need the Ford Tow Package to get that rating.
I definitely want to be safe, not cut the life short on my vehicle. Any idea what my vehicle can safely pull? And would I need anything additional to pull a travel trailer safely?
Thanks in advance!
33 REPLIES 33
Thermoguy
I have a 2016 Limited Explorer with the same engine, but with the tow package. I think the AWD is a limitation as well as the transmission. I have only pulled a couple small trailers, the largest a 8' uhaul, so no real experience. But, I can say that I have had issues with the transmission trying to find the right gear with no trailer. I could not imagine pulling 3-5K with that transmission.
I would look at pop up trailers. But stay within the vehicles limits.
Convington
Lots of information in there, appreciate it everyone. I still contacted Ford, 2 Ford Dealerships (total, contacted another one today) - Ford says 5000# but requires a transmission cooler, Dealer said 5000# (I don't trust his answer at all, BTW). May have to go with a popup until the Explorer is replaced, which i don't want to do ever because it is nearly paid off - so might be SOL.
APT
I would not recommend any high walled RV without the HD tow package. At a minimum, get a heavy duty transmission cooler. Even with the HD towing package, Ford has a limit that excludes any high walled RV. Check out Page 13 on frontal area.
Stick to popups or replace the tow vehicle. Your Explorer has market value. And equivalent valued more capable TV can be found, but it will probably be a couple years older.
2017 Subaru Outback 3.6R
blownstang01
dodge guy wrote:
I have a 2013 Explorer Limited with the factory tow PKG. I was towing 3 snowmobiles (around 2k lbs with the trailer). the engine will not stay in 5th gear, you`ll be lucky to keep it in 4th most of the time. I wouldn't tow anything more than a large PuP. I`ve seen people tow TT`s with them, I don't know how they do it.
The 4th and 5th gen Explorers are nothing like the 1st and 2nd (and even the 3rd gen for that matter). they are car based. the early ones were more truck based.
This is your answer ^^^. We have a 2014 Explorer (with tow package) and before we bought a M/H we "tried" to tow our 3,500lb camper and the Explorer 3.5 would struggle just to go 60 mph and would stay in 4th and even downshift to 3rd on slight inclines. Luckily, we still owned our 1 ton diesel dually and used that as this generation Explorer won't get out of it's own way towing anything heavy. I couldn't imagine what fuel mileage would have been. Not to mention wear and tear.
rexlion
I'm the type who would find out exactly what my vehicle lacked versus the ones with tow package, and add the components which are needed to protect the drive train. That said, with the non-turbo 3.5L I'd be hesitant to tow anything with a frontal area greater than 7' wide by about 100" high or over 3500 lbs dry. And if I were pushing those limits, I'd keep my speed at 60 mph or less and lock out overdrive.
About the weight... 3500 lbs dry is likely to be 4200-4500 lbs when loaded. Even more critical is the hitch weight, which your vehicle can probably only handle 500 lbs and this is very easy to exceed. I once had a 23' Rockwood of (IIRC) about 3400 lbs dry and 380 dry hitch weight. But the fresh water tank was up front. I bent a rear spring on my 2000 Mountaineer (rated for 6000/600). You'll want to get a scale (Sherline makes a good one) and weigh the hitch before starting out. BTW, for safety you always want at least 10% of the total TT weight on the hitch for proper handling.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
jerem0621
It would be a whole lot cheaper just to install a transmission cooler. They can he purchased and installed for a few hundred or less.
My Tahoe didnโ€™t come with the factory HD towing package. I added a transmission cooler that is about 2x the size of a factory job.
Trans temps do not get over 189 and typically stay at 176ยฐ Towing a 7,000 lb loaded TT. My engine temps stay at 220ยฐ same as not towing.
The chassis are the same Despite what coolers are installed, maybe different shocksโ€”-cheap. Maybe different cooling packages but radiators and coolers are cheap too if you need to upgrade them.
Anyway, you donโ€™t have to spend an extra $20k just to tow a trailer. It doesnโ€™t take that much HP to pull a TT... aerodynamics play a much bigger role IMHO...a 20 ft long full profile trailer has to punch the same hole In the air as a 30 ft full profile trailer so the aerodynamic load is the same between the two.
Setting up the WD hitch properly is important.
Thanks and JMHO
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
carringb
OP - A truck isn't absolutely necessary. Your current vehicle just isn't equipped properly. My sisters Explorer Sport does fantastic towing the ski boat. A new 2020 Explorer (which is RWD-based) equipped with the towing package would be even better for towing 5,000 pounds.
2014 ORV really big trailer
2015 Ford Focus ST
Grit_dog
Navigator
Navigator
Agree with the posts thus far.
On the flip side if youโ€™re good with towing it easy, keeping to say 55mph and not running through mountains, I believe 100% that the vehicle will not have any issue with it.
But personally I donโ€™t have the time nor self control to putz down the Highway for days at 55mph.
Another option, is rent a truck for a couple weeks. Either a rental outfit and lie to them about towing or rent from an Equipment rental place. May cost you $700-900 to rent the truck but you can drive the wheels off of it and turn the keys in when youโ€™re done.
dodge_guy
Convington wrote:
ugh. ok. sounds like we will be looking at lighter popups for right now and if we really want to do this - invest in a truck, I guess. Kind of a bummer.
I agree. And I am far from a member of the weight police, but with the current gen Explorers they just arenโ€™t up to the task of a tall trailer. You would be OK with a 3500lb loaded PuP.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Lwiddis
"Any idea what my vehicle can safely pull?"
Safely PULL and CARRY...you, spouse, kids and stuff in the Ford plus tongue weight and hitch weight.
Convington
dodge_guy
BTW, towing anything that heavy in the summer will require more service than normal. the PTU is one major one. they are not serviceable and only hold a 1/2 qt of gear lube. so it gets cooked pretty well being next to the catalytic converter, engine and transmission, towing will only make it worse. I just did the fluid on mine (drilled and tapped for an NPT drain plug. the fluid came out like thick mud! it took 5 drain and fills to get it looking normal. it will be done again at the next oil change. then once a year after that. the water pump is another issue on the 3.5`s.
Wife Kim
Son Brandon 17yrs
Dog Bailey
Jebby14
id say so go. tell the missus to take a close look at popups (might get away with a very light hibrid (look around 2500 lb) but even that will pull like a billboard. If planning to purchase, consider switching to a half ton pickup in that world (i ahve a 2016 f150 crew cab wife has the 2017 explorer) we both agree the f150 is better at most things, it was cheaper to buy, cheaper to insure, cheaper to fuel and more versatile. only reason we didnt get her one to match is its tough to fit in her lot at work.
if looking to rent maybe go with a class C instead and not have to worry?
Q: Whats brown and sticky???
A: A Stick....
carringb
Based on the 2015 Ford Towing Guide, the Explorer is only rated for 2,000 pounds WITHOUT the Heavy Duty Trailering Package.
When my sister bought her 2016, we simply made sure it was equipped with it.
However one of my friends had a Ford Flex without it. My research then indicated the only difference on the Flex, was the Heavy Duty Trailering Package added an Engine Oil Cooler. It's likely that your Explorer is missing this component, but Explorer (Sport and Police Intercepter Excluded) also had smaller brake rotors than the Flex, and might also lack a 2nd transmission cooler, but I have not confirmed this.
I know you already have that Explorer, but you'd be far better off selling that one, and buying a Sport or Platinum model with the 3.5L EcoBoost. This will tow 5,000 pounds effortlessly.
2015 Ford Focus ST
Convington
Thanks, I missed theoldwizard post. Thank you for mentioning that one - was very informative. I think 'loaded weight' also includes passengers in vehicle and any luggage and stuff inside the vehicle also, right? (vehicle being the explorer, not the camper)
