Tango__AE7UI's avatar
Tango__AE7UI
toyo tire recall
I received a recall notice from Les Schwab regarding a recall from Toyo Tires on their LT 235, LT 245, LT 265 series 16 & 17 inch E10 tires.
So I'll be taking the truck to them this morning to verify if mine are part of the recall.
    Thanks for the heads up. I checked the Toyo web-site and mine are definitely part of the recall. Will go to the dealer on Monday.
    The recall was for a manufacturing defect causing the cords to separate with the potential for the tread to part ways with the sidewall and that would not be a good thing.
    Thanks for the info.
  • The recall was for a manufacturing defect causing the cords to separate with the potential for the tread to part ways with the sidewall and that would not be a good thing.
  • As it turns out, my tires were not on the list because of the newness (2014). The recall was for 2011-2013 which was not clear on the recall notice but I wanted to make sure.
    Another customer was having his replaced at the time I was there.
  • "Made in Japan" Toyo Open Country HT - Tuff Duty …….LT285/75R 16 123Q E/10 also on the recall list……I will let Les check them out too!
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,129 PostsLatest Activity: Apr 26, 2025
