โApr-26-2015 04:32 PM
โApr-27-2015 02:01 PM
โApr-27-2015 01:33 PM
acritzer wrote:fla-gypsy wrote:acritzer wrote:fla-gypsy wrote:
Nose down is better than nose up but level is always better. Are you using an adjustable draw bar?
I'm embarrassed to say I don't know what an adjustable draw bar is. I can raise and lower the height of my hitch ball though.
Sometimes referred to as a shank
http://www.reeseprod.com/products/weight-distribution/wd-shanks/xDqAUvNOHeJOEQE!QxI!fWu5X4bpIN4D
Oh,yeah. That's what I have.
โApr-27-2015 01:14 PM
โApr-27-2015 12:16 PM
โApr-27-2015 08:37 AM
acritzer wrote:Turtle n Peeps wrote:
I'm going to say you got it on the money. There is several reasons to have your trailer down in front.
#1. You will get "slightly" more tongue weight and that is a good thing.
#2. The trailer will cut the wind better. It sounds like a minor issue but it really can add up and make a big difference in mileage over years of towing.
#3. This is a big one. During panic braking the nose of the tow vehicle will dive because of weight transfer. When this happens the back of the tow vehicle and front of the trailer will raise up. This is not a good situation because the weight of the trailer will try to lift the back tires of the TV off of the ground. Braking with two tires is not a good thing and you want all tires of the TV braking equally. When the nose of the trailer is down like you have it; it will form a straight line when in panic braking mode; which is a good thing. I say leave it. ๐
Thanks. I'd like to be "done"...but also want to get it right. Sounds like level is the best, most agree on that. The question really is, how much nose down is OK.
โApr-27-2015 07:10 AM
โApr-27-2015 07:03 AM
โApr-27-2015 06:34 AM
โApr-27-2015 06:27 AM
โApr-26-2015 06:03 PM
poncho62 wrote:
Is your tow vehicle sitting level?.....If so, move the hitch up. If tow vehicle is drooping at back, you should correct that first
โApr-26-2015 05:32 PM
โApr-26-2015 04:44 PM
โApr-26-2015 04:41 PM
โApr-26-2015 04:35 PM
