carringb
Oct 19, 2015Explorer
Smokey Lew wrote:
Hi Bryan, thanks for your quick response. The setup I have for the bags is a compressor under the hood of the truck that feeds both bags form a single line. The airbag gauge shows the pressure from that single feed line. I guess you have to assume the pressure in both bags is equal. I think my next step is to pressure up the bags and get under the truck and spray some soapy wanter on the lines and see if I get any bubbles.
Got it. In your case the single air line should balance pressure in the air bags, which means both tires should be roughly equally loaded. So... I'd lean towards normal tire variation.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 24, 2025
