Off_Pavement
Aug 05, 2015Explorer II
I'm not a UTB expert by any means, so here is my 2cents worth...
For starters, I'd go through the UTB troubleshooting guide being sure to check voltages carefully... US Gear UTB Troubleshooting Guide
Is it possible your pedal cable needs adjustment or the cable kinked?
I recently had to replace my UTB compressor with an aftermarket vacuum pump. The new pump provides considerably more vacuum than the standard UTB compressor which may an issue for a different vehicles brake system.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
