Upgrade to 5th wheel
Taxman2436
I have a 2019 Ford F-250 6.7l diesel. Iโ€™m looking at a Grand Design 320MKS but want to make sure my truck can haul it. According to the brochure the trailer is 10,721 UVW. According to Fords towing guide the truck will tow 14,800 lbs. Iโ€™m thinking that if it will I may need to beef up the rear suspension. Also, Iโ€™m not sure how โ€œUVWโ€ relates to the actual weight I will be towing. Also looking for hitch recommendations.
Thanks for any help provided.
Lenny
Taxman2436
Sturbridge, MA
2022 Ford F350 6.7L Diesel
2023 Grand Design Reflection 320 MKS
50 REPLIES 50
2112
I calculate it this way:
6340-2840=3500lbs. This is your rear axle limit
3500-200=3300lbs. Subtract 200lbs for the hitch
12000 X 0.25=3000. Guesstimated pin weight if the 12,000lb trailer is loaded to the max
3300-3000=300. You have 300lb margin on your rear axle.
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
Taxman2436
OK, so the rear GAWR is 6340 and the RAW is 2840. So, it appears the 12000 for the loaded trailer would be OK, but would I be pushing to the limit?
Taxman2436
Sturbridge, MA
Cummins12V98
What is your trucks RAWR? What is your RAW ready to tow. The difference is what your pin weight can be. Multiply that number by 5 and that will get how heavy a loaded 5er can be. Reality is I would multiply by 4 as many 5er's have up to 25% pin weight.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Lwiddis
Twenty percent of the max gross weight of that 5er is 2800 pounds of pin weight. TOO much for a 3/4 ton truck IMO when you add passengers and stuff in the truck.
BB_TX
You need to look at your truck's payload capacity. And the unloaded pin weight plus about 20% -22% to get an approximate loaded pin weight. That pin weight vs your payload capacity is going to be your limiting factor.
Lwiddis
Whatโ€™s your estimate of the loaded pin weight? With all your stuff and passengers in the truck are you within payload? โ€œBeefing upโ€ levels the truck but doesnโ€™t increase payload.
