Kansas_couple's avatar
Jun 17, 2015
Use WD setup with 3/4 ton?
I bought my TT about a year and a half ago. TV at that time was a half-ton Suburban. I knew before the purchase I needed a WD hitch, dealer set me up with an EZ-Lift.
However the Suburban has since had several problems and I finally bit the bullet at the end of January and bought a 2014 Ram 2500 gasser. I've looked at some other folks' setups and noticed some 3/4 ton trucks didn't have WD in use.
My TT is a 23-footer with a dry weight of 4100 lbs. Any thoughts as to whether I should stay with the WD setup and possibly adjust the chains for the newer TV, or just have the weight on the ball?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
