valhalla360
Nov 27, 2021Navigator
20's shouldn't be an issue. I do like to drain the waste tanks but even that is likely fine if it's only getting down to the mid 20's.
Do Disconnect from city water (fill the fresh water tank...it won't freeze overnight.
Make sure to use the furnace, the heat bleeding off the living space should keep any pipes from freezing.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 17, 2025
