mhbell
Apr 08, 2019Explorer
I got the Flat Tow Harness Kit and had it installed by the dealer. I did make one modification to it. I cut the wire ahead of the fuse and ran it to a SPST switch with a safety cover and mounted the switch on the dash. I can leave the Fuse in instead of removing it when I want to use the jeep without towing. It works great and I no longer have to insert the fuse when I want to tow. I just throw the switch. I want to add a LED indicator light so I can tell when the switch is in tow mode. I am thinking maybe I could hook the LED to one side of the switch and the other side to ground. Not sure if that will work or not.Mel
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: May 14, 2021
