Sjm9911
Jul 26, 2020Explorer
wa8yxm wrote:
There is a warning about "Streatchable" hoses in the world of RV's (like the Pocket hose)
They Retract when pressure is lost. and can pull the inlet off an RV.
Easy fix it is true but easier not to fix.
For taste.. IF you use a filter (And I suggest you do) put it as close to the RV as you can get it. Not at the park end of the hose but at the RV end. You may need a short (like 3')hose for the final link. Or the ultra short that comes with the filter in some casews and a 90 degree elbow connector.
Its not a stretchable hose. At lest the zero g isnt. Its the same lenth. It just fold up easier, is lighter, deploys faster and takes up less space then your drinking hose. Thats because it dosen't have a rigid jacket. It has a cloth or nylon jacket So it will not pull out anything.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
