down_home's avatar
down_home
Jun 03, 2016
Water pressure
For about as long as I remember we've been told to set pressure regulators at 40 psi. If I wanted a good shower I turned on the pump because inlet water was not enough.
Well,we had to change out the water pump. It's an Aqua flow with 5.3 gallons per minute at 65psi, at ten amps.
It can be set to 75 lb according to the website unless it is referring to the 115 volt version.
Motor is good just need to rebuild the pump section.
Haven't heard from the factory if they sell rebuild kits.
Put in a box and in the bay for a spare.
It has lasted 12 years, with a lot more use than the 3900 miles on the odometer.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
