โJun-07-2016 10:12 PM
โJun-08-2016 04:51 PM
Carrier wrote:
What make of hose did you use?
โJun-08-2016 03:59 PM
SoundGuy wrote:dewey02 wrote:
Wow, Soundguy. That was an incredibly effective solution. How do you have the piece of plywood mounted to the sponge, and how is the sponge mounted to the floor?
The pump is mounted to a piece of plywood with four screws that extend down into the foam, as well as some carpenter's glue between the wood and foam. As I recall I also just put a dab of glue on the underside of the foam to secure it to the floor but that's not really necessary as the pump with the hoses connected to it really can't go anywhere anyway.
FWIW, we've owned numerous campers over the years from popups, to a hybrid, to travel trailers and I've tried all the usual pump silencing methods everyone else has tried - different pump, isolating the pump, foam pipe wrap, securing water lines with nylon cables ties, adding an accumulator tank, you name it BUT none of them,even in combination, has ever been anywhere near as successful as significantly extending the length of the output hose before it interfaces to the trailer's hard wall PEX water lines.
โJun-08-2016 01:12 PM
โJun-08-2016 11:19 AM
โJun-08-2016 11:10 AM
โJun-08-2016 10:54 AM
SoundGuy wrote:Sam Spade wrote:
I think some gromets and an old mouse pad probably are my solution.
While isolating the pump helps, dampening pump vibration that radiates along the output hose is the solution that will absolutely render any of these pumps "silent". As clearly demonstrated in my video that dampening element was a 25' loop of potable water hose. :B
โJun-08-2016 10:01 AM
โJun-08-2016 09:24 AM
โJun-08-2016 08:43 AM
โJun-08-2016 08:41 AM
Dick_B wrote:
Please search this Forum for `water pump' then search the results for `noise' or `noisy' or `loud' etc. This has been discussed at length. It's usually not the pump...
โJun-08-2016 07:14 AM
โJun-08-2016 06:16 AM
โJun-08-2016 04:28 AM
โJun-08-2016 04:22 AM
โJun-07-2016 11:10 PM
