Dog_Trainer
Feb 17, 2015Explorer
OP I think you are going from thread to thread trying to justify pulling a TT with an under rated TV. A properly adjusted WDH will give you a good tow experience and properly distribute the weight for that best experience. Go to the thread which gives you the proper set up procedure and follow it. In one of your posts you talk about a carrying capacity of under 1300lbs a WDH no matter how it is adjusted will increase that capacity it will do as noted and re distribute that weight. No matter how it is re distributed it will not change by much the amount of weight being carried by the TV.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
