2112's avatar
2112
Jul 11, 2013
What Caulk Should I Use
Water weeps out between the aluminum track rail and either acrylic or plastic shower. I see it running from this location and am sure the caulking has failed.
What is the proper clear caulk for this repair?
Thanks
  • 2112's avatar
    2112
    It's designed to drain out through the inside from slots at both ends so that didn't seem to be a good idea. I agree that grunge under the rail is in my future.
    I was thinking of pulling it and caulking the whole area under it and resetting it but it's too new to go to that extreme at the moment.
  • caulk it on the inside so you don't have grunge growing under the rail.
  • 2112's avatar
    2112
    I sealed it with RTV and it held up great.
    Thanks
  • I use pro flex clear - same caulk I use on the outside windows.
  • 2112's avatar
    2112
    I have some Dow Corning RTV 3140 silicon. I'll use that then.
    thanks
  • Had a similiar problem with my shower when new. Used white 3M industrial bathroom silicon caulk on all internal seams on the shower. All leaks gone, 2 years now.
  • GE Silicon Kitchen and Bath will do the trick. Cut out the old product, remove it thoroughly before putting down the new. Less is more. Wet your finger and make a smooth track.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 24, 2025
