What Equalizer Hitch to Choose
tscholz1
We have a 2013 Coachmen Freedom Express Liberty Edition 320BHDS. Dry weight 7914#. Max cargo 2744#. Tongue weight 841#. Tow vehicle is 2003 GMC Sierra 2500hd diesel long bed. I have an equalizer hitch from previous trailer but it was a light weight trailer. This trailer is at least 3000# more and I don't feel this hitch is adequate for the new trailer. I love the equalizer system and prefer to stick with it. Equalizer has a calculation to choose proper hitch. Not sure what amount of pounds I should use for after axle. Usually have an ez-up, light weight chairs, tool box, portable wagon in the back of the truck. Also some trips we have two kayaks on top. How many pounds of gear on average do people load in their camper? Does this add to tongue weight. I thru some numbers and came up with the 90-00-1200 model. Is this the proper one or should I go with the 90-00-1400 model? Thanks for any input you can give me.
Tod Scholz
2012 Coachmen Freedom Express Liberty Express 320BHDS
2003 GMC Sierra 2500HD
16 REPLIES 16
AH64ID
AngryBert-63 wrote:
I was going by the factory numbers.
As for my camper - 6K and 8 lug. Solid builds these Northwood/Outdoors RV units.
Yeah the 2011 Brochure shows 8100, but my sticker is lower.
Very solid, it's one of the reasons I bought it. We spent a lot of time on not so nice roads and the overbuilt chassis is great for that.
-John
2018 Ram 3500-SRW-4x4-Laramie-CCLB-Aisin-Auto Level-5th Wheel Prep-Titan 55 gal tank-B&W RVK3600
2011 Outdoors RV Wind River 275SBS-some minor mods
Winnebago_Bob
AH64ID wrote:
AngryBert-63 wrote:
AH64ID wrote:
Get the 14K model, it uses the same bars as the 12K model with a stronger head.
If I had known that back in 2008 when I bought my hitch I would have gotten the 14Klb model.
That being said my 12K model does great with my 1250lbs of TW and 9-10K GTW.
Doesn't that model have max weight of 8200?
GVWR of the trailer? 7900 according to the sticker, but that was based on dry weight + 1750lbs and not structural design. As the camper got heavier thru the years the GVWR went up with no frame/axle design.
The camper has a 10K frame (at least, it could be a 12K) and 5200lb axles, as long as I don't exceed those I don't worry about the weight. Average TW is 1250ยฑ50lbs and TAW of 7500ยฑ500.
I haven't seen many campers with a 10K GVWR that are built on stronger frames, to include toy haulers. Most the TT's or TH's I compare it to that have 2K lb higher GVWR's have smaller frames and often smaller axles.
I don't treat it much differently than the sticker on the door of my TV, it's there and as long I am know about the design I don't worry about it.
I'd be willing to be we have very similar frames, seeing as both our campers are built by the same parent company. Looking at the specs of yours it comes with 16's, so does it have 6K or 5200lbs axles? Both axles are the same (brakes, bearings, etc) but the 6K spring pack is stiffer. 6K's can be had with 8 lug or 6 lug hubs. I like the OEM 16's thou, I just had to fork out the cash to swap to 16's.
2017 Winnebago Aspect 27K
myredracer
1400 lbs
The Reese dual cam WDH is a nice setup because of it's self-centering action. Trunnion style bars are a little easier to handle and store.
After you have the WDH installed and you are all loaded up for camping, I would suggest going to a scale to determine the trailer's actual weight (GVW) and the actual tongue weight (TW) so you know exactly where you are at. That will verify that the bar rating is good, will give you remaining cargo carrying capacity and what payload capacity is left in the truck. You can also use the numbers to figure out exactly how much weight is transferred between axles and if the WDH could use some fine tuning.
AH64ID
-John
Winnebago_Bob
AH64ID
-John
Winnebago_Bob
Need-A-Vacation wrote:
TS,
Make sure if you don't already know you don't install a ball with to long of a shank. Good choice btw and some great advice!
Bert,
It is suggested to include any cargo weight in the truck bed that is behind the axles plus your potential tw in deciding which bars to go with. I don't see where it would hurt to go with the 1500lb bars. Best thing to do is give Reese a call and ask them. I know I recently emailed them asking a question, and they responded within a day or so.
Bailed on Reese and chose Equalizer #1400.
Need-A-Vacation
TS,
Bert,
Bubba J- '13 Chevy Silverado 2500HD LT CCSB 4x4 6.0
'16 Jay Flight 32 BHDS ELITE 32 BHDS Mods Reese DC HP
WDH Set Up. How a WDH Works. CAT Scale How To.
tscholz1
Thanks for your replies. I bought the 1400lb one from Amazon. Now I just need to switch them out. Happy camping!
Tod Scholz
Winnebago_Bob
Funny - I'm in the same boat as you - only a few minor differences.
My trailer GVWR is 10,400, dry hitch is 772. I'm installing a Reese SC with 1200lb bars.
I know if I max load the camper I have the potential (on paper) to overload the bars (10,400 X .013 = 1352) but that isn't exactly reality. How and where the cargo goes is key to influencing the tongue weight and I can't see how I can get that much cargo forward of my front axle on the RV.
The way I see it, I'm more in the sweet spot with the 1200lb (600-1200lb range) than with the next available 1500lb (800-1500lb range).
I know that on paper I can overload the bars but practically and physically I can't imagine how I would do it with the camper's interior setup.
Thoughts? 1200lb or 1500lb?
I know this is a bit of a thread jack and I apologize, but the weights were so close I figured I'd ask the same thing -
Which way would you go?
Ron3rd
My trailer is about 1,000 lbs lighter than yours, and I went with the 1200 lb bars if that is any help. I agree with the 1400 lb bar recommendation.
Equilizer Hitch
Honda EU2000
kvangil
2004 Jayco X23b
2005 Nissan Pathfinder LE 4x4
handye9
I too, would go for the 1400 lb model.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
BarneyS
I think if it were me I would get a 1400lb model hitch. Your tongue weight is most likely going to be north of 1200lbs.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
