โFeb-20-2019 05:18 AM
โFeb-20-2019 05:59 AM
โFeb-20-2019 05:56 AM
fj12ryder wrote:
I have a triple axle toyhauler with about 2500 lbs. on each tire. I usually run my Sailun "G" rated tires at 90-95 psi. I've run them from 90 psi to the max of 110 psi and find that the smoothest ride is around 95 psi. They are nearing 5 years old and have excellent wear patterns, i.e. none.
My advice is to experiment and see what works best for you. I know one poster on here who runs his "G" rated tires at 85 psi, but that just feels too low for me.
โFeb-20-2019 05:54 AM
โFeb-20-2019 05:52 AM
MarkTwain wrote:rbp111 wrote:
I have a trailer which has Sailun G rated tires. The maximum PSI of air is listed as 110 PSI. I was carrying 90 PSI but recently was told that the maximum PSI, that is 110 PSI is the amount of air I need to carry.
Which is the amount I should have in the tires?
Look on the side of the tire. The max PSI number is on the side. I run the max psi when I am towing and then run 65 non towing.
โFeb-20-2019 05:51 AM
โFeb-20-2019 05:50 AM
โFeb-20-2019 05:33 AM
โFeb-20-2019 05:27 AM
โFeb-20-2019 05:25 AM
