โApr-15-2015 03:18 PM
โApr-27-2015 09:37 AM
โApr-27-2015 07:05 AM
โApr-21-2015 06:20 AM
Clay L wrote:thestoloffs wrote:Clay L wrote:
We found what they called a transport chair that would fit through the hallway going to the bedroom. It folded up and fit in the trunk of my Honda when we took him to doctors appointments.
Unlike standard wheelchairs, which has large wheels that can be reached easily from the seat, transport aka escort chairs wheels are only a few inches in diameter.
They are designed deliberately to limit the user's own ability to move themselves without supervision; they are designed to have someone else push the user around.
Unless the intent is to have an escort to push their chair, or if the user's legs have enough power to push the chair, an escort chair is probably unsuitable for the suggested usage.
You are right. Our friends left it with us after they no longer needed it and I just went out to the shop to take a look at it. I had forgotten that it is intended only to be pushed by someone other than the user.
โApr-20-2015 11:08 AM
โApr-19-2015 02:43 PM
โApr-18-2015 07:57 AM
tonyandkaren wrote:mr. ed wrote:
Actually. I'll have assistance getting in. I'm not driving yet so a friend will be able to help. Yes, it's a bit awkward but I'll still be getting therapy and hopefully will be more mobile soon.
That's good news. If I'm assuming right your fifth wheel has slide outs which should give you plenty of room to move around. You may want to have someone install grab bars in the bathroom to make it easier for you.
If you think that you won't be using a wheelchair very much in the future you might be able to find a used one on craigslist. A folding one will fit in any doorway and can be easily loaded into your truck or a car. I have a rigid frame chair because I put it through a lot of abuse but a folding one is fine for light duty.
โApr-16-2015 05:19 PM
โApr-16-2015 04:12 PM
โApr-16-2015 03:32 PM
โApr-16-2015 03:10 PM
tonyandkaren wrote:
Will you be able to climb the steps to get into your fifth wheel? If not the entry door may have to be widened because lifts need extra room even when used with narrow wheelchairs. This site has a lot of different types of lifts - http://www.startrackslifts.com/
Another option might be to buy a used RV that has been modified - http://www.disableddealer.com/item_search.asp?category=1020
We fulltime in a small class C that has been built to make it accessible for me(Karen). It has a Super Arm lift, a wider door, the dinette is cut down to half and the bathroom door and a wall section has been replaced with a folding door. With just those few alterations I have access to everything in the motorhome and room to spin in a complete circle at either end.
Please let me know if you have any more questions.
โApr-16-2015 03:04 PM
JoeGood988 wrote:
Almost all fifth wheel trailers have steps inside. Bathroom doors are usually 24-30"...As far as I know, unless you order a custom unit, a class A motorhome is all on one level. You can order a chair lift on some models also.
โApr-16-2015 02:04 PM
garyhaupt wrote:
Would one of those ATV type winches work in this application? Using a remote controller..one could be 'on line' going down and then for the return. Just asking.
โApr-16-2015 12:47 PM
โApr-16-2015 12:04 PM
mr. ed wrote:
I've located some narrow wheelchairs on line that may work in my fifth wheel. Are any of you using one? Any advice appreciated.
