May-13-2023 11:49 PM
May-30-2023 01:23 PM
bucky wrote:
Anyone that thinks the big rig driver should have done something needs to reconsider.
Do you want a 80K pound load running across the median and killing himself and oncoming innocents?
The truck driver was correct in maintaining his lane or it would have been much worse.
May-30-2023 09:51 AM
May-30-2023 04:53 AM
May-29-2023 03:47 PM
May-29-2023 10:16 AM
bpounds wrote:
I'll get flamed but oh well...
I'm not suggesting the professional driver was legally obligated to do anything different, or even morally obligated to do so, but I do believe he should have seen this coming. First time I watched it I could see right away what was going to happen, just by the way the RV was closing on the other truck. The pro driver has better visibility from his cab than we do from a dash cam. He just chose to stand his ground and maintain speed. There was a time when professional drivers would do everything they could to avoid this kind of thing, even when the other drivers act stupidly.
May-29-2023 08:48 AM
May-15-2023 07:33 AM
Bobbo wrote:cptqueeg wrote:
the C is no longer passing the semi on his left as quickly.
Whether that's just a change in perspective as the c comes into range of the camera, something that I think I'm seeing but isn't reality or the semi in lane 2 accelerating trying to close out the opening so he doesn't get cut off from the right lane by the MH.
Or, is trying to get past the semi in the right lane as fast as possible. I know that if I am trying to pass a vehicle and the speed differential is small, I will speed up to get on past. Then, after getting a few car lengths ahead, slow back down to my preset speed.
May-15-2023 07:32 AM
rhagfo wrote:cptqueeg wrote:
^^^It would be interesting to know if the truck was accelerating or decelerating and it's speed. Usually most people have to be seriously frustrated to make those types of moves.
It's 100% the class C's fault but I'm curious what led up to the class c driver make that move.
If you watch closely, it appears the trucker is catching the truck ahead in the right lane, so I would say passing. Just the Class C driver letting his testosterone take over thinking.
May-15-2023 07:04 AM
May-15-2023 06:31 AM
May-15-2023 06:11 AM
May-15-2023 03:37 AM
May-14-2023 07:06 PM
I disagree with this statement. I have seen vehicles flying down the interstate, swerving from lane to lane, without ever being held up.
May-14-2023 06:46 PM
cptqueeg wrote:Looks like the semi in the #1 lane was passing at a small speed differential and the C was impatient. The window was closing as the C pushed through.
May-14-2023 06:24 PM
