where or can I get LED bulbs ?
luberhill
Three of my MH's interior ceiling lights have what I think are NOT LED bulbs, they have a switch on the side, oval and have two little bulbs that get hot
Can I get LEDS for these or isn't it worth it ?? Just to save battery juice when dry camping
Thx
2013 Winnebago Sunstar 26HE
35 REPLIES 35
Lynnmor
luberhill wrote:
so someone here said the " regulated " bulbs cause issue with the TV...how do I know if they are unregulated ??
Thx
If the voltage is stated as 12 volts, it is unregulated. If the voltage stated is something like 9 to 14 volts, there is a regulator. Of course the accuracy of advertising can be suspect. If you can see the circuit board side of the lamp, the regulator is usually a round can device.
Here is an example of one stating 12V, but has the regulator can on the back. Of course this is an incorrect listing. Can on Back
luberhill
Thx
luberhill
Took me to a Google sign in which I donโ€™t havr
Lynnmor
Go to this website and do what it says: Photo Posting
I just did it as a test.
luberhill
Ok these are 921 bulbs, think of the fixture being football shaped oval. It has two bulbs .. one bulb plugs in the narrow end of the oval or point of the football and faces the other point, then the other bulbs plugs in the opposite end at the narrow and faces the other bulb..
So I can wish I could post the pic or I could email one of you guys the pic
enblethen
Fixture uses a 921.
By going to Winebagoparts.com op has a Vista WFE26HE
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
westend
luberhill wrote:
Ugggg I still canโ€™t get it to work
Looks like model PY-826 ??
Standard 2 light with switch in the Winnebago 2013 26 He
The type of fixture isn't applicable. Remove a bulb and search it for markings or describe the bulb. There are replacement LED bulbs for every type of incandescent bulb.
'03 F-250 4x4 CC
luberhill
Lynnmor
luberhill wrote:
Lynnmor wrote:
Until you post a photo of the lamp, we have no clue what "end to end" means. Just buy what fits.
How do I post a photo from my photo library ??
Here you can find help with photo posting: Photos
luberhill
fj12ryder
JMO but I wouldn't bother with bulbs like that. I would get the downward facing ones. Might as well have all the light going down instead of part of it getting reflected. My LED's face down and they work great.
Howard and Peggy
"Don't Panic"
enblethen
Sorry: More like these.
921 LEDs
Bud
USAF Retired
Pace Arrow
Lynnmor
luberhill
enblethen wrote:
These are the ones I got for low voltage patio lights and MH.
921 multi-pak
Are you sure yours are 921 lamps. How big are yours?
Those are not led and are what Iโ€™m replacing or trying to
