โApr-18-2018 02:51 AM
โApr-21-2018 11:06 AM
โApr-21-2018 09:31 AM
โApr-21-2018 07:52 AM
โApr-21-2018 07:05 AM
Dave H M wrote:
i run my firestones with no pressure in them when empty like Grit Dog does.
Why do you "have" to run the 5 psi Lou?
โApr-21-2018 06:30 AM
โApr-20-2018 05:45 AM
โApr-20-2018 04:39 AM
Grit dog wrote:SweetLou wrote:
My 2013 Ram DWR came with air bags, I wonder why yours didn't? In any case, I have owned air bags and Timbrens. I would go back to Timbrens if I could. They are not air bags and when not in use , they won't change the ride of the truck. These trucks are stiff enough and air bags by design are always connected even with minimal air. Just my opinion, but like I said, I have owned both.
Because no pickups โcomeโ with airbags in 2013 and now the only ones are 1500/2500 rams with air ride or select 3500s with the half springs and assist bags.
As far as brand, theyโre air bags and they all work fine. Fwiw I bought some used firestone bags about 5 years ago and theyโre still good.
And, no, air bags wonโt affect the empty ride if you let all the air out. And no need to worry about the min pressure requirements if youโre not hauling enough to bottom out the suspension. Some bags are also rated to run empty because they have a bump stop in them.
โApr-19-2018 02:07 PM
โApr-19-2018 08:50 AM
โApr-19-2018 08:16 AM
SweetLou wrote:Cummins12V98 wrote:corvettekent wrote:
With a 3500 you should not need any air bags.
I agree especially with that light of RV.
Even more reason to have Timbrens. They work only when the load needs them
โApr-19-2018 05:20 AM
โApr-18-2018 06:23 PM
โApr-18-2018 04:00 PM
โApr-18-2018 10:41 AM
