FIRE_UP
May 17, 2015Explorer
bighatnohorse wrote:klutchdust wrote:
Interesting concept. The controller sends a signal to the electric brakes on a trailer so why not to a unit on the toad. I am sticking to the ready brake, when things go wrong I can visually see what it could be in a minute or two, electronics? Not so much.
That's right. My car hauler simply plugs into the trucks 7-pin connector and the brakes work on the car hauler.
I'm going over to Freeway Trailers (local shop) tomorrow and ask if they can do it.
Well, saying that your trailer brakes work on your car hauler simply by plugging into the 7-pin connector is a pretty vague answer. What, may I ask, is the controlling factor, that makes the brakes work, on the trailer? Do you have a break controller in the cab of your truck that, is wired into your 7-pin connector? Something has to regulate the amount of braking that your trailer applies. So, a bit more of an explanation might be appreciated.
OP,
Well, to be honest, your Jeeps brakes are hydraulic. And because of that, you need something to apply pressure on the jeeps brake system, to activate the Jeeps brakes.
A brake controller, normally applied in an aftermarket sense, something like Prodogy or Tecumseh, is a graduated, many times inertia activated, electronic brake signal, sent to the ELECTRONIC brakes on a trailer, not a vehicle. The brakes on many, if not most, trailers are electric and operate via a magnet being pulled towards a disc or drum brake back there. The more amperage applied to the magnets, the greater the braking power is applied to the trailers drums etc.
So, I'm going to assume, that your integrated trailer brake controller in your truck is factory and, it's an electronic one. That controller is designed to control the electric brakes in a trailer.
Hence, that is why there are so many aftermarket Brake units that are placed in the toad, to press on the brake pedal of the toad, to use the toads own brake hydraulic system, to apply the brakes. The one that I and many others use is called the Ready Brake. It PULLS on the brake pedal to apply pressure to the hydraulic system.
But, unless I'm way off here, your integrated controller will not work. And, even if you wanted it to, you'd have to come up with some mechanism that, would convert, the electronic signal emanating from your trucks controller, to a mechanical one, that would apply the brakes hydraulically to your Jeep. Hope this helps some.
Scott
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
