Skipg
Jun 20, 2020Explorer
Why 30 amp and not 50 amp
Why not build all RV’s with 50 amp service ? With AC, microwaves, electronic water heaters plus numerous other electrical appliances we take with us it seems to make More sense to have 50 amp
time2roll wrote:Fisherman wrote:??? Very much available for self install.
I wish we could still get those old convection furnaces, no noise, no battery use.
https://www.ecomfort.com/heating/williams-direct-vent-furnaces.html?
Combine with a Mini-split A/C for efficiency and you should be very comfortable.
I'm wonder if it doesn't, at least somewhat, have to do with History.
There were once campers that had no electric at all and had things like Propane Gas Lanterns build into the camper. Then they had 15 amp campers. (I once had a camper that had no AC and only had a 15 amp plug.) Then there was 30. Now they have 50.
Times change and it takes awhile for the infrastructure to catch up.
DrewE wrote:Bobbo wrote:
But, it is also true that a 50 amp trailer has access to 100 amps of power. You just have to use two circuits to access it. Sometimes, simplifying a subject can get the concept across even though the technical details are wrong.
I think it is both simpler and more correct to use units of power when comparing power, rather than units of current--doubly so when one of the current values must be incorrectly stated for the comparison to work out. \"Amps of power\" is a nonsensical phrase, if taken at face value. In the context, it is a shorthand form (or a shorthand way of thinking) based on the assumption that the voltage is invariant, when in fact the different voltages are at the heart of the matter. Similarly, saying that a 50A circuit supplies 100A is also something of an absurdity, and is also forced by incorrect assumptions about the voltages. Comparing power using the proper units--watts or kilowatts--avoids all the confusion.
linnemj wrote:
I wonder if the market would pay more for improved axles and suspension, higher quality tires, better furniture and better quality control? Every new buyer doesn’t understand the value of these items but experienced buyer certainly would!
